do people not just use the natural forks in the tree for redirects that they do not intend to return to??
or is there a saftey reason against it?
thamks carl
  • Replies 43
thamks carl
Yes. Whatever is easiest in each situation.
Sent using Arbtalk Mobile App
Revolver is a no crossloading a krab and the possibility of the gate rubbing open, A bob or a F8 bunny ears with a krab work great, a locked of ring and ring is good as it doesn't matter how many redirects you take.
Can't picture how the ring would work without threading the entire tail through it.
Do u have a photo?
YOu install it from the ground as normal and you tie an alpine so it jams on the small ring, then when your finished you pull down on the small ring side and retireve it as normal, no photos im afraid mate. I am on about a cambium saver there is another anchor with just a ring.
eee, don't like the look of that! A ring would be much better. I reckon it would depend on line angles and bark smoothness, so prob a case of judgement on each tree.
What specifically don't you like about this Dan? Is it because it's on a stem rather than horizontal limb and could end up with components cross loaded...?
This set up really appeals to me for the lack of gear needed and the ease of retrieval.....
It may be coincidence or it may be intentional, but both the images Ben posted show fixed sided pulleys rather than swinging side plates..... Is there are reason for that....?
This is what the dude who's pics they are told me.
'Derrick Martin
Works with one or two open (not much friction) redirects.
I plan my climbs a little different when using a top tie, will work a little harder (normally doing the hard part first) so that i make retrieval easier.'
Adding a pulley or ring to a top-choked system will not be of much help when it comes time for retrieval after going through several redirects. If multiple redirects are anticipated, use either a base tie, or a ring-to-ring type anchor like Ewan showed. If using a Butterfly knot as a stopper, it is a good practice to capture the eye with a carabiner or link and clip it to the retrieval end of the rope.
Dave
Dave
How can you have multiple 'retrievable' redirects Dave...? Surely once you've pulled one through the first [or last one installed depending on how you look at it] ring/pulley it won't go back through the next ring/pulley the butterfly comes to...? :001_huh:
And why do you recommend a base tie? That's my preferred set up anyway but I don't see how this can allow you to create multiple retrievable redirects... :confused1:
Thanks for being patient with me! :biggrin:
Natural crotches :biggrin:
