i,am going to try and build my own hydraulic splitter
i just google my ram sizes n pressures etc to get the tonnage .As for the ram its a bucket tilt ram of a jcb and the hyd tanks of a dumper truck engine is a honda gx340 11hp off a gennerator all made to bolt on off to betterfie later i,ve had it running at over 5500 psi the two welded rsj,s bend and the ram starts to bannana so i,ve set it up with the relief valve coming in at 3200/3300 and its working fine i just need to change the 3 high pressure feed pipes so it will work faster without having the engine working over half revs
  • Replies 21
Sounds like your nearly there mate!:thumbup1:
