ok spud i need a switch for a glow plug tester round momentary type
4 terminals 1 set n/c 1 set n/o 8 amp 12v any ideas?
Mmm, a photo is always good - am I thinking that the N/C set become open and the N/Oset become closed on switching the switch on? Does the switch lock in the "on" position
Is it a rocker, toggle or plunger type switch?
RS is a damn good place to start to spec any switch - you can usually get enough of the part number off the switch to get you started!
Has the connection part of the switch got some of the contacts missing as it could be a DPDT switch with the N/O connection on the first pole missing and the N/C connection missing on the second pole?
Anyone following this:001_rolleyes::lol:
He did ask!
Anyway, a DPDT switch modified will work, just need to buy one that will fit, has the correct current/voltage rating and then nip off the unwanted contacts - RS Components are best although Maplin may do something suitable!
thanks spud tried maplins, cpc could not help i will strip it down and get a pic of the switch it is a non lock plunger type in a diesel tune glow plug tester so you press till ampage stabilizes then read of the time in seconds 5,10,15, 20 sec
3 pins - I found another switch that fits perfectly but it's a 3 pinner at the back - with a light- can i use it and just forget about the light spade?
cheers
Yes you can forget about the light terminal.
