  • Replies 27
mmmm thinking buxtons,service,scary been told two and a half weeks and £100
two 40ft oaks sat and sun aswell,
faifull old 3120 coming out to play again
Let’s find out what’s wrong with it first
First make sure it’s got the correct oil and not some thin 20/40 that can just run through the pump.
Remove the bar and chain and the chain tensioner cover, spank the saw up and look to see where the oil is coming from, report back.....
ok im gonna go for it ,not tonight though its a bitt of a beast,ill do it tommorow and report to you lot asap,thanks again lads and rich your a legend mate
No probs mate. Pm has been sent also. But spud is also the legend of arbtalk and saws aswell. :thumbup:
just out of curiosity what is the round plastic like circle at thebottom of the saw looks like the other side of the oil tank????????
Thats a plastic bung that pushes in to the AV rubber, best thing you can do is to clean the saw up and leave the saw to stand to see where the oil is coming from - it may be just oil coming off the chain and catching on the side cover.
This can happen if you are using a shorter bar and havent adjusted the oiler from using a much larger one.
You may have one of the oiler seals gone or just be trying to push oil in to a blocked bar oil hole - the only way it will go is between the bar and the mount!
spud fix this bitch will you please,:blushing::confused1::confused1:
hertfordshire???im working in winsford at the moment thats next door isnt it?????
Pretty close - just 160 miles away as you are near HEREford and not HERTfordshire:blushing::001_rolleyes:
Just clean it up, put it on a clean piece of paper and see where the oil is coming from overnight and then take that part of the machine apart!
It may be coming out of the breather vent, is the machine actually oiling the bar and chain as it should - this should really me an easy fix - did Nepias 064 recently and the part was a few quid and labour something like £40
actually spud its cheshire mate but irrelevant if you cant do it,,im gonna take your advice and strip it tommorrow i think,ill let you all know how i get on,,,,,,[ say a prayer for me ]
