  • Replies 34
We still have it... It goes, it chips wood. We have to keep it for a few years before we can get something else. It's a bit annoying to spend that amount of money and be disappointed with what you get.
It sounds like a strange spec chipper although you are in a different climate, the 95xp is generally for fibrous & stringy material with foliage hence the 90 degree chipdisc & single feedwheel. It should have no problem with logs etc but not the best without autofeed as you will have to control manually. Because the feedwheel fits close to the chipdisc it shouldn't jam that much, autofeed can be retrofitted which will also give you an hour clock if required.
Hope you get sorted.
Excellent machine. Looks ugly, like everything is on the outside, but that makes it easy to work on. Very good build and design.
Only hassle is it's not metric bolts etc.
I'd have one if I didn't have a poxy 3.5t truck.
Sent using Arbtalk Mobile App
have used a couple...awesome machines. Very heavy but everything you need to get to is accessable. One of the ones I used had a winch fitted and was a very useful bit of kit :thumbup:
