if it was a clutch spring the chain would more than likely be flying around fairly
No, I had the same problem with my 020 I tried adjusting the chain, then the tick over, I then thought the bearing might be goosed and when I took the side of lo and behold, a clutch spring broke.
But your right, they normally whizz round fast, mine was just creeping
ahhhh..one other thing it could be.....if the clutch springs have just ceased, in which case a good spray with wd40 will cure it.
ceased=seized?
