Replacement schrader valve for compression tester?
Adamam
Interesting point. I shall have to go through my stock of new valves to see if there is any difference between the cores of lawn tractor and lorry valves.:001_smile:
I doubt you will find something suitable, the compression gauges have a very low spring rate and havent found anything from bicycles, automotive or heating aircon related that work!
