Big oak that took what I imagine is a sheet lightning strike 10 or so years ago.
There are dysfunctional strips running along the top side of the lowest laterals.
One popped off during high winds 7/8 years ago, & one delaminated at the union 4 years ago (we reduced this back to collar)
  • Replies 99
Tearing into the collar that near a footpath...and this is not the Ecology forum...:sneaky2:
Here's a tickle taken out of a liriodendron with a Humongous Hole (~50% circ., >80% hollow)mid-stem. All cuts to nodes that presently have laterals. left 2 lower limbs alone--not much impact on stability, and they nourish the woundwood around the canker.
Plus they were over the neighbors' yard and essentially their problem. :001_rolleyes:
Lightens the load, c u in 3 years to restore. Prognosis: sprouting at cuts 1-2'/year, able to take off 1/3 next time to mitigate crowding and bad forks.
It could be..........let me toss a coin :biggrin:
Bit more than just a tickle.
Had it been reduced before?
"It could be..........let me toss a coin :biggrin:
well then better do it quick b4 folks get the wrong idea :blushing:
"Bit more than just a tickle.
mmm i've seen your gang scratch a lot harder!
"Had it been reduced before?
Untouched by the hand of man as far as i know. had the helper climb (it was raining) :001_rolleyes: but he did not report previous signs of pruning.
We've been known to scratch when there's been a big itch :biggrin:
The lirio 'looks' like it has a significant diameter shift (in the before shot) as if subjected to a re-iteration after a prune ?
Obviously Liriodendron is a native your side of be pond, but I don't recall our mature planted specimens here having that kind of crown framework?
That tulip's defo been pruned before:biggrin:
They don't grow like that normally...
EDIT: David put that much more eloquently than i did:lol:
pruned by saw or storm? the before shows central leader bent as if it was broken. trunk is riddled with cankers, not just the big cavity--no david no fb's seen.
i suspect the wind tore the top off, but i'll ask DJ to post the in-tree pics he got.
could've been lopped early on and that's how it got cankered. chicken or egg first?
Not done by saw imo
