Petzl Sequoia bridge
WorcsWuss
Snot for that, was thinking of using one as the basis for an rw tether..... Cheap, neat and 3 options all around the right length.... Stiffen it up and presto....
Course I could be wrong, but for around a tenner it's not an expensive experiment.....!
Thanks for info though!
Just had a look at a couple I've got. One has big eyes, the other has small:confused: both from the same supplier
Probably pot luck as to which you get but yeah you should get a crab through either, dmm shadow gets through the little one with ease.
How were you planning on stiffening it?
Do try the smaller dmm ones, think you might be surprised.
The bridge also comes in 3 sizes which is handy:biggrin:
Where you going to shrink wrap it?
Thought I'd probably do it in my shed..... :001_huh::lol::lol:
I have looked into the quickdraws, if I stumble on one I'll get it, but they don't seem to be stocked by the usual suspects.....
I do have a very short hitch, going to start with a 25cm bridge and go shorter from there.....:thumbup1:
Not sure yet, whatever I have lying around, will experiment but so far am settled on covering it with an off cut of aeris cover inside clear shrink, binding black silage wrap repair tape around something under that, not sure what yet....
