Coriolopsis gallica on ash. David, this was the fungus we thought was Daedaleopsis confragosa on that stump from last year, I do believe! Purchasing Fungi Europaei vol. X on Polyporaceae (£69 on Summerfield Books) has been a revolution for me!
Pseudoinonotus dryadeus (Inonotus dryadeus it was formerly known as). Causes a white rot - a rather slow one, too. Makes oaks buttress out in a pronounced fashion - known commonly as the Eiffel Tower fungus (plus other names). :)
As a heads up try not to bash an entire bracket off if it is large - take photos and get a little slice (like a cake).
And the reason for not bashing the whole bracket off Chris?
Will the fungi then turn all it attention and energy into wood degradation as apposed to some on fruiting and sporolation?
Sent from my SM-G920F using Arbtalk mobile app
Hi guys! I need youre help again went for a walk and found a few i was unsure on 1483114611759.jpg.af3a904ee568a7f37f721de4dddf707d.jpg
First two were found on the same beech presume one to be more fresh than the other type of ganoderma?
The third was found at the base of a very very large oak had about four clusters of it all well past maturity rootplate seemed to have alot more reactionary wood on tue side with the fungus. I thought maybe grifola frondosa?
fourth one was found on the tip of a piece of deadwood on a douglas fir. Absolutely boggled me.
Found on a beech any idea what species of Ganoderma?
the most coolest mushroom ive found yet and cant find any trace of what it might be even my mushroom book any idea?
once again thank you very much! [emoji2] [emoji2]
Hi guys! I need youre help again went for a walk and found a few i was unsure on [ATTACH]215430[/ATTACH]
[ATTACH]215431[/ATTACH]
[ATTACH]215429[/ATTACH]
[ATTACH]215432[/ATTACH]
[ATTACH]215433[/ATTACH]
[ATTACH]215434[/ATTACH][ATTACH]215435[/ATTACH]
Think the first two gano's maybe pfeifferi.
Certainly looks like desiccated Grifola on the oak.
Douglas brackets look like Phaeolus schweinitzii.
The large Gano is more than likely australe.
If you can, try and get shots of flesh and pores when you take I'd shots, really helps with pinning them down.
Not sure on the last specimen but the gills remind me of a brittlegill (Russula species) the inverted form looks unnatural and may be due to temperature or some other interference with its normal development. What tree was it specifically near, the woodland looks mixed?
Edited by David Humphries
thank you very very much :-) great help as always will get soore brackets in future :) and it was directly underneath a large douglas fir. nearly missed it if some deer didnt run past next to it.
