Hi I've got a Vermeer 186 that has just seized. It had a kohler command 20hp in and I was wondering if anyone knew if it was possible for me to replace it with a 25hp engine. Any advice would be great. Cheers
should go strait in,
Should be fine as long as the engine mounts the same. So long as the belt pulley or clutch fittings are the same then it should be ok. I just upgraded my engine on my splitter with a bigger engine and that's fine.
From reading other forums about this engine I get the impression there was a manufacturing problem where the gasket blew due to an issue with the bolts. I've got a feeling this happened with mine, on what i was told was a newish engine when I bought the machine. Anyone else had this problem?
I had one on my old Carlton and never had any problems with it, maybe you just had a dodgy engine. Can you not get the old engine rebuilt?
