Hi , i came to start my 190 turbo 2008 today after a year of non use, and having re charged the batery. But only the 1st egnition light comes on not the glow plug light , and nothing is hapening ?. There is the usual clicking that you hear whilst waiting for the glow light ( no light) to go out but nothing else . Not any sound from the starter motor. I have very little mecanical knolage , any advise greatfully reseved
Check all the connections on the reverse of the panel, try a different battery, make sure than the rotor can be rotated....then post a thread on the Timberwolf section of this forum and you will be contacted by their technical people.
Hi Mark
The starter motor should turn when the ignition switch is moved to the crank position. (providing you do not have a stop switch activated)
As this is not happening I would suggest either the battery is faulty and not holding the charge you gave it or you may be a loose electrical terminal, or even the starter motor needs assistance due to its long laid up interval
Give Timberwolfs technical help line a call on 01449 765820 they will be able to give more in depth checks to carry out on your chipper
Hope this helps
