Stihl MS341 not sparking???
HRG Tree Services
Yes - disconnect the kill wire off th ecoil and try again, reduce the coil to flywheel gap - try A4 paper rather than the typical business card, check the resistance between the plug connection and the kill contact - if it is open circuit then the plug connection is probably open circuit.
If all this fails then the coil is shot:thumbdown:
