560xp crank
daddyola50
hi all my 5 month old 560xp is at the shop for a new crank under warranty, the clutch center had split and chewed the threads on the crankshaft end never seen that in 23 years of cutting , about 400 pounds worth i think . anyone else seen or heard of this problem before
Not yet ! Hopefully not again .
2 of us use 560s in the woods 8 hrs a day. one crank sheared off at the clutch due to what we think was the thread not being machined straight that cracked the clutch then stressed the crank. mines be ok the usual problems. We both have a cracked exhaust in the same place right on the top so thats the next warranty replacement.
:001_smile:
:001_smile:
yes mine gets used in the woods all day too hope my exhaust is not the next problem , had one of the av springs snap too
both saws have had identical problems i might as well list them!!!
starter side case broken
rear av spring
full rebuild due to front gasket case leak under the exhaust
clutch spring
exhaust crack
One saw sheared the crank.
All been done on warranty which is nice! :001_smile:
rear av spring
clutch spring
exhaust crack
cheers for that will update when i have another prob
