Hi,
Sorry I have been slack and have not posted on the forum for a while.
Any advice on this would be great.
I have been told about a fine old Native Oak tree that apparently has Meripilus giganteus and is identified to be felled. I remember (?) reading about some rare occasions where this combination has been recorded? Also is there any record of a Native Oak tree failing at the base from Meripilus? I think this fungus may have been misidentified and is Grifola. Either or I am struggling with this.
Thanks
I've seen Merip on native oak before, can't say I've ever been around one that's failed due to it yet, but it probably hasn't been long enough yet
Sent from my Galaxy S2
I know of only one tree that failed Q. robur/M. giganteus failure.
Q.cerris is a bigger problem and treat as with beech with extreme caution, Q. robur/petrea would appear anecdotally to have some resistance and is a far more common occurrence than we would be convinced of from the literature alone.
and as you hint is often miss identified because of the latter:001_rolleyes:
