Evening folks!Looking at purchasing a fuelwood kindlet pro in a few months time.Problem i have is there 3 phase & i dont have access to 3 phase so im gonna go down the generator root.I need help with what size generator to purchase machine is 7.5kw so what size generator do i need id rather have extra kva available to allow spare power to possibly run other machines at the same time if required.
Any help appreciated as already asked two electricians on the shooting field to no avail!!
I dont know if 3 phase requirements match that of single phase.
Also will be looking for a decent generator if anybody knows of one cheers Darren.
  • Replies 20
I would be interested to hear peoples views, as I am in the same boat as well, currently using a single phase pto generator. I will in the near future be planning to purchase a 3 phase kindling machine as well as running other 3 phase motors. I am considering mounting a 3 litre transit engine onto 2 RSJ's and run these through a David Brown back end/gearbox. I would like to try and run the engine on LPG as I have heard that Diesel engines gum up due to not being worked hard. I would appreciate any comments or criticisms that people have . I cannot justify 5K at the moment on a self contained generator.
Hi Bob looked into this two year ago when i was going to go down same root.Wasnt sure about whether would be suitable or not as kindlet pro requires alot of juice to get it going dont quote me on this but something about a delta???start i think.But thanks for your input.
The momentary startup load on electric motors is far more than their rated running kw.
Also for example, a fluorescent light may run at 30w but may need 150w draw on startup, so if you have a bank of 20 lights it's a fair old startup current
If I was running a 2kw motor I would buy a 4kw genny
Also need to allow a bit more if you have a long cable run
Edited by Dean Lofthouse
Thanks Dean i understand what your saying never thought about the length of lead cheers
Sorry for delay in response cant find my software on any of the pc's in office. So found another on on the net. To start a 7.5kw motor 3 phase dol you will need
39.65 kva.
