I used to use what must have been the equivalent model to this years ago, it was the same description then, a [Semi-Pro saw. I think this is about right, it would have been fine for occassional use or part-time use at best, it was not up to full on proffessional use. That was probably over 15 years ago so they might be slightly better now.
i have a 681, 80cc professional. very well built similar to stihl really.
i would say their semi pro saws would be as good any of the big names equivilent
Yeah calling it semi pro does makes it sound crappy. But everthing husky rear handle, smaller/lighter than 353 is also classed as "home owner" on there website.
Only rear handle small saws in same size classed as pro from the big two companies is the stihl 201 rear handle version which is very expensive.
But I suppose then you have the small echo saws etc but the power weight ratio doesn't seem as good for them... :001_smile:
