Hi woodpicker,
weve got a 526 boxer mini skid steer on tracks that can have over 50 attachments and are currently working on a chipper for the front that will drive around the side of a domestic house.
it has a rotavator/tiller head that should mulchyour brambles etc with ease. its 25 inches wide diesel powered 26hp .
specs below:
For easy maneuvering in tight areas, gates and sidewalks
• Operation at full width offers increased stability
• Two pump, 20685 kPa hydraulic system offers 54.88 L/min of hydraulic flow
• Ideal for a variety of industries
Model # 526DX Specifications
Engine Power: 26 HP
Engine Manufacturer: Perkins
Engine Description: 403C11 Diesel
Tip Capacity: 953 kg
Hydraulic pressure: 20685 kPa
Dump Height: 1524mm
Travel speed: 3.7 MPH
Ground clearance: 127mm
Ground pressure: 24.8 kPa
Overall Length (without bucket): 1956mm
Operating Capacity, 35% of tip load: 333 kg
Operating Capacity, 50% of tip load: 476 kg
Hydraulic Auxiliary Flow: 54.88 L/min
Overall Width (fully extended): 1105mm
Overall Operating Height (Fully Raised): 2489mm
Weight (without bucket): 1093 kg
Hinge pin height (fully raised): 1930mm
Track Width: 22.86mm
check out our website and call me at wetherby depot for free days use to see if it works.
Baz
