Timberwolf 125PH grease points
cain_christian
Hello,
I bought a Timberwolf 125PH and I'm trying to get hold of a manual, but in the meantime I wonder if someone would mind sending me pictures of the location of the grease points so that I can grease it in the mean time?
Thanks,
Christian.
Shadow of the Apple Tree
[email protected]
Shadow Of The Apple Tree: Tree Surgeon, Hedge Cutting, Felling, Tunbridge Wells, Kent
Hi Christian
If you need a copy of a manual please contact Timberwolf Technical help line.
To supply you with a manual we will need the serial number of your machine and we need to confirm some other details of the machine and we can send you one elecrtonically.
As for the grease points there is on on each infeed roller.
Use a good quality multi purpose grease - do not use a graphite based grease.
You can contact us on 01449 765820 (TW tech Support)
Hope this helps
TW Tech Support
