  • Replies 61
Could use a ring pull a bight through it chuck a small swing cheek on the bight and that would give decent friction, Are you still using the Lj Dan?
Sent from my GT-I9300T using Tapatalk 2
Yeah ascent would be an issue but it would be streamlind for work by clipping the second crab from the sj in to the pulley, what do you use as tether on the Lj i just picked one up to use with the Rw
Bit of a derail but I use a 21cm dyneema, girthed onto the shackle. I'd like to try to put on a 7cm cut away I have but can'f figure out how to attach it without removing the shackle off the LJ, plus I don't have one of those weird three pin tools for it.
