My current set up is 5m of 10mm spectra speed running through a cinch with black diamond magnetron karabiners and an ocean vectran thimble loop, love it works really well for me. [ATTACH]120443[/ATTACH]
nice krabs! i'll google those right away. never seen em before.:001_smile:
  • Replies 147
Ok so this evening I got some new 10mm op and spliced it onto a snap lock . Seems to feed out of the cinch alot better than platinum. ImageUploadedByArbtalk1366478919.453718.jpg.1d0be4540d72b36725e51a820fff8513.jpg
Sent using Arbtalk Mobile App
How many wraps of your prussik are you lot using on your side strop?
4 to 6 depending on the weather. If its a wet slippery day Ill use 6, in a classic prussic.
But this really depends on the rope you are using as a base for your lanyard.
I like three strand ProMaster or similar, and when wet I find the extra wraps help with gripping, and with not binding ?
Some ropes are not really affected as much by being wet.
To be totally honest it really varies from day to day, week to week, I play around with different knots sometimes, and sometimes Ill leave it the same for a while.
Ok so this evening I got some new 10mm op and spliced it onto a snap lock . Seems to feed out of the cinch alot better than platinum. [ATTACH]121318[/ATTACH]
Interesting! i swapped 10mm OP for platinum in my strop, I got annoyed by how 'baggy' the OP felt. That was with a hitch mind you..... :001_smile:
Looks smart though Joe :thumbup1:
Platinum is definitely more rigid but
Because op is thinner it tends better and releases slack out by just tugging on the krab, I can't imagine op lasting long as it very baggy. ImageUploadedByArbtalk1366796297.984944.jpg.c9604ec6bd4f60d5a26a2e2ddec9c225.jpg
Well I just use this now and all the hassles are gone.
[ATTACH]121853[/ATTACH]
Sent with my iPhone from me, to you!
That looks pretty big, how much rope does it take again
