What Chipper??
HRG Tree Services
i highly rate the jensen a530. worked behind one for 2 years and had no problems with it. even with 1400 hours on the clock.. the first time i used a timber wolf i found out all its problems in the first 10 mins of using it.. i use timberwolf 190s at work and there shocking (weve got 2 of them) ive herd great things form green mech. another firm i used to work with had a grenmech cm220 with almost 3000 hours on the clock.. if you got the timber to the rollers, it would destory it.
hope this helps
ed
timberwolfs are good but we get alot of blockages and have to dig it out by hand. weve also got a jenson and havent had a problem with that, the only thing that needs doing is changing the rollers as theyve worn down a fair bit. also the new greenmec is really fast and didnt have a problem with it. not sure which model but it was on a turn table
Can't speak of greenmechs but the jensen or ok but my experience of the 540 is don't do it the smaller machines I hear great reviews along as its not a refurbed unit( I know someone who's spent loads an a reconed unit )
Vermeer I have a soft spot for love the heavy-duty build but towing weight is a bummer tryed there large turn table machine and loved it I personally own there bc150 and its far better that the jensen 540s we have at work.
Timberwolfs imo or so over rated the only feature I liked on them is the feed buttons the baby v- twin powered jobies are sweet for what thay are.
Where is the nearest greenmech dealer would it be forget company name but there dumpers drove fair oak ??
