You dont need a ratchet.
I remember at school almost 50 years ago there was a treddle lathe.
The treddle drove a large flywheel via a crank.
The flywheel drove a small pulley on the tailstock via a round leather belt.
Depending on which way you started it, you could run it clockwise, or anticlockwise.
Flywheel smoothed out the motion.
easy.
robin wood uses a traditional lathe ,and he turns big bowls, he uses a mandrel to wrap his leather rope around which gives more torque,,and a big larch pole,nobody said it was easy,,hence they moved on to the treadle lathe, then belt driven,then motor,,,if they could have used a motor they would have, !! i use both, mainly between centres on my pole lathe now adays!
(rob copied his lathe from george laylies lathe which is in the reading rural life musuem).
My question wasn't if its possible, I have started turning a big bowl with a normal pole-lathe and it works ok, its just a complete thug. My question was more about efficiency. Big bowl + momentum. the ability to conserve that momentum would be more efficient
Read more
