Going to change the relay on my QwikChip which the no stress hasn't been working.
Havent changed the relay yet but when i put it in my car to test it the horn came straight on so am hoping its the relay at fault?
Were sells the magnetic sensor that does the fly wheel for the no stress.
Also is there any where to order a new no-stress control box at the last resort.
The relay probably isn't the same one as on the car, the car is momentary which only engages when a voltage is applied, most no stress systems employ a latching relay which changes state and stays changed when a voltage is applied.
For the sensor try RS components
Jez Smithers is the man to talk to, he works for TS Industrie in this country. His mobile number is 07825 012261. Jez has been around machinery for longer than most and is honest enough not to fill you full of BS.
