Tpo question
Paul Cleaver
Can anyone tell me the current standing on the following scenario
Tpo boundary trees are on neighbours property - overhang proposed for sympathetic pruning - I should know really but been out of touch on such matters:blushing:
is it:
subject to councils approval on the work - offer the arisings back to the owner?
reg
Paul
Exerpt from the 'blue book':
Nuisance
6.9 The LPA's consent is not required for cutting down or carrying out work on trees so far
as may be necessary to prevent or abate a nuisance.
67
The term 'nuisance' is used in a
legal sense, not its ordinary everyday sense.
6.10 Under common law
68
a landowner can cut the branches from a neighbour's trees if
they overhang his or her property. The overhanging branches are regarded as a 'nuisance'
and may be cut at the boundary between the two properties whether or not they are
causing any damage. The cut branches, including any fruit, remain the property of the
neighbouring owner. The same rule applies to encroaching roots.
69
Two properties must be
involved, and so householders cannot claim that the trees in their own garden are the
cause of a nuisance to themselves.
6.11 Whether the branches or roots of a protected tree can be cut back in this way under
the exemption has not been settled by the Courts. In the unreported case of Sun Timber
Co. Ltd. v Leeds City Council (a case involving overhanging branches) it was decided that
the exemption applies only where the nuisance is 'actionable', in other words where the
overhanging branches are causing, or there is an immediate risk of their causing, actual
foreseeable damage. If this interpretation of the exemption is correct the LPA's consent
would be required under the TPO before cutting back branches or roots which are not
causing damage.
I would ring the tree officer and ask for his/her guidance on this before any pruning occurs!
is it:
reg
Paul
Yes and yes but if you do return them to his property with a degree of care there isn't a lot they can do about it.
Perrin & Ramage v Northampton BC [2006] EWHC 2331
Nuisance means actionable nuisance, not just an overhanging branch. Irrelevant that an alternative scheme, ie root protection, could also abate nuisance.
I think this went to appeal though, and don't know what the outcome was.
