Does anybody know how big you can get a polytunnel. I mean the span across (between the semi circle) not the length without any support poles in between.
I'm aiming for about 12-13m if that's possible.
Cheers
From memory, I think the maximum possible width on a single span tunnel is 28 feet, which is the width of the ones that I have erected. Beyond that, you need to go to a multispan, where the overall width can be as much as you want, albeit with central supports as opposed to clearspan.
Thanks. That's what I thought. I've had a bit of a google but not had a chances to ring any of the companies up to ask directly.
It looks like I will only be able to go about two thirds of what I had hoped.
