Looks well made but as you're the one using it I would have thought only you could answer the question. Where did you buy the rollers as I could do with a couple extra on my deck?
they are Boat trailer rollers I got off ebay, I think £4 each, they are a bit rubbery, rather than a hard plastic, I will see if i can find the company name for you.
That is going to need some substantial footings, or it will sink with the first load of cord.
Looks like it will do the job
I live up in the hills in mid Wales, there aint nothing but rock under the grass around here lol:biggrin:
I am going to bodge one up in an hour will put up some pics. I think yours will need another beam through the middle and another roller. Best place place for rollers is probably towsure.
Personally, i'd say it's too big (length-wise). Also, it isn't steep enough so the logs won't roll onto the end easily. I would make the angle around 20-30 degrees wheras at the mo it looke more like 10 or 15. The problem with having a long table aswell is if the logs get stuck (likely due to the relaxed angle) you'll have to poke them with the telehandler and that is fraught with danger!
I would chop it in half and make it steeper, then you've got something more usable.
Knocked this up with a few g cramps this morning. I would give yours a try and then add some mods if it needs it my best tools have been perfected from bodges along the way.
