Idea for failed ropes.
Tribaltree
nice idea.
I cut ours into short lanyards with an eye at one end choked up onto a biner and a double stopper at the other end as a kind of handle...ideal for cut and holds on branches that are too risky to hold by hand but not enough of a problem to rig...cut - swing - drop.
Alternatively, if you are a 'crafty' type, you can make it into a rug!
Coil the rope tightly around itself flat on the floor so you get a big spiral. Tack stiches every now and again so it retains shape. Flip it over, fill the spaces between strands with a bead of something like flexible sealant. Then stick a piece of tough material (canvas, tarp, whatever) on the back. When it's all dry, cut round the backing material and you can keep your favourite rope forever, and continue to spn yarns about each damaged bit (core shots, burns, cuts, etc). A ready-made sandbagging mat.
That was a bit 'Blue Peter' really, wasn't it? :blushing:
