Ive had a pipe bust on a tipper, Ive collected a replacement pipe and fluid ready to tackle it tommo evening - Just thinking will i need to bleed the system at all once the pipe is replaced, or will air escape from some sort of return (didnt notice one on there).
thanks
Dean
The first couple of times will be a bit spongy but the air will be expelled when you close the ram, the remainder will be carried back tot he tank by "bubbling" into the oil, no need to bleed or vent it.
