  • Replies 52
They all sound sort of "farty" compared to two strokes, the common fault is the tappet clearance and the carbs need a bit of a tweak once in a while. They are a bit fragile around the valve area but just need a bit of love:lol:
Didn't think my guys are giving them any love. Closes thing is rolling around in the van as they drive along.
That is pretty typical of kit when you haven't paid for it:sneaky2:
Well, the Clacton dealer agreed with Tripp Batts that it's running fine. However they said it's a 4 stroke running on 2 stroke mix, whilst TB said it's a 2 stroke with valves. No difference there then :)
A mechanic friend of mine says it's running s###e, so not sure what to do now.
I have a 4 mix hedge cutter. Must have got 3 tanks of fuel through it before it died.
Had the tappets adjusted twice in 2 hours subsequent use - now it is perfect for 5 minutes then dies. We don't even take it out now. Heap of dung in my view!
We have a 2001 2 stroke which keeps bumping along and an echo. The 4 mix is just gathering dust. A failed attempt to reduce emissions, it reduced reliability much more.
