been feeling the heat over last couple of days any reccomendations for a lightweight pair of type A trousers
cheers:)
Sent from my GT-I9000 using Tapatalk 2
Hi Monkeyboy.
I sort of solved this prob yrs ago - not quite HSE approved.
I used an old pair of A- trousers and cut down the back of each leg from the waist band, sewed up the cut seam to stop fraying, then sewed on x3 - 2" wide webbing with matching buckles on each leg, plus reversed the belt. They come off like the trousers on the 'full Monty', to give an idea (with a pair of cotton trousers underneath).
They are brill for 'quick jobs' as they go on in a miniute, but at there best when it's hot as I put them on and off between saw work.
I will try and get Iain to put up a picture later.:thumbup:
