When faced with the problem of filling net bags with logs, decided against buying a log bagging device from Fuelwood at over £200 :scared1:
Instead, made a few of these out of an old sheet of aluminium. Simply pull on the bag, stand on the ground, fill with logs, draw out device and tie-off bag.
Effective and simple (and cheap)
  • Replies 35
Where do you get your net bags? I see lots advertised but would rather get recomendation.
How many of my scottish pennys would that cost
Sorry don't accept foreign currency...............(occasionally shiny beads if accompanied by a valid card)
Wat size nets do you use?
As it says on the E-bay listing 45 x 60 cm
Edited by Arran Woodfuels
Been using a cut up old Addis bin myself, not as sturdy as yours mind!
  • 1 month later...
