it was only to see if the dyneema could be pushed through the gap.
as the spacer is the same size.
as for the pic, unless 'users' fully understand the pinto, they should not be using one.
and on a final note...does anyone use a larks head?
i do, every day :biggrin:
  • Replies 75
The large spacer for the pinto rig is only designed for 10mm rope really.....and the eyes on the pinto are bigger than the spacer...
Good point, I have never seen one, I have looked at an alternative, the 'antal low friction ring' 10x7.
  James Atkinson said:
the petzl spacer fits perfectly between the cheeks check it out Here's a first - Treemagineers pulley compatible with Petzl yea that would be cool adam id bring it over to yours and you can splice it on, how much would you want?
Just pay for the length you want mate, think its £3 ish per meter.I will not charge you for doing it.. Plus i will get to meet you in person...:thumbup1:
Read more
