  James Atkinson said:
with a larks head would it sit straight or would most of the weight be pulled onto one cheek of the pulley?
As long as sits right, and a spacer in place, there would be no issues.
Under pressure, the pulley would equalize the forces.
  • Replies 75
would a larks hitch fit through the spacer?
i reckon the dyneema will fit, try'it, if you put some thread through to help pull it, it would for sure.
  tuttle said:
t'was easy....
That should not be used like that mate you risk queezing the two side cheeks together, causing it to fail and more than likely injure someone.....:thumbdown:
Always use the spacer when fitting direct to textiles
  tuttle said:
t'was easy....
Yeah that's rubbish. How are the other ends of the larks foot connected to each other? Why not just do it properly by a splicing, b continuos loop c direct tie to pinto eyes d steel crab or maillon????
Read more
