Confused ms260 16" 67dl chain ???
predator
i,ve just got round to having a go dressing my chain up and confused as most the chains for sale use a 3/16 file but the chain i have on takes a 5/32 file better.Whats going on lol has it had wrong chain fitted as i got 3 new chains with it from ebay
is it righttorwrong ????? as the cutters are only small :confused1:
The trouble is, that if the cutters are too small for a 3/16 file but take a 5/32, then the chain is most likely a 3/8 low profile and therefore a different pitch. If this is the case, it wont match your sprockets. Please dont use it again till you are sure you have the right chain, you may cause damage to the saw, or yourself.
i will when i have the moneys replace them etc i will re order 3 new chains and a 1 mtr pull starter cord as spares oh a oil cap for my ms 260 as it leaks chain oil thanks for the offer of help rob just not upto facing people at the moment etc
thanks gents i will send justin my order very soon etc i got troubles with my banks at the moment closing barclays opening a new acc with tsb etc its all a pain
funny you,ve said that because i,ve had troubles with chain tension and its thrown one chain off thank goodness for the chain catcher eh!!
i wont/hav,nt used it off late but found the small file thing after deciding to re dress the chain up to get it ready for use etc thankyou for the good advice
every days a school day for me learning cheers
Not only that, but I doubt that the drive link gauge matches the standard Stihl bar 1.6 mm. At least I have never seen a 3/8" LP chain with that drive link gauge. The widest 3/8" LP gauge is, I believe 1.3mm which would be VERY noticable, when placed in a 1.6mm groove - it would wiggle about a LOT.
I think you should have a serious look at the drive sprocket (pitch), chain (pitch/style and drive link gauge), bar (gauge and nose sprocket pitch). Only then will you be able to tell what fits with what, and avoid doing (further) damage to your equipment.
Edited by morten
