What model would you go for in stihl for a
Small Saw & Bar size
Medium Saw & Bar size
Large Saw & Bar size
Β
I have,
Β
ms200, ms200T both 14"
Β
ms440 18"
Β
066 25"
Β
ms880 36"
Β
climbing wise Ms200T with 14inch bar used to have 12inch which although faster and more powerful the 14inch can cut more quite happily.
Normal groundsaw either a ms260 16inch or personally I use and Ms361 with 16inch and then have a spare 20inch bar and chain for medium stuff also it's a good saw for bigger dismantles.
For big stuff i use an 88 with 3ft bar.
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
