Yup, pretty straightforward, had one fitted to my Pro Tipper, which is very similar set up to an Ifor trailer.
Not had much luck with the chinese remotes on ebay for about £15, they work fine at first then pack up after a couple of months.
The Lodar system is probably the best, they cost about £120+vat
true but fed up with the plugs breaking get left on and trashed and dirt getting in if you live in a area that does sugerbeet you would understand , cheers for the replies lad's
Read more
