Hi,
Being an owner of a large woodburning stove and wanting to avoid oil heating costs ina drafty house, I have over the last 5 years become something of a weekend wood cutting warrior. I get three large lorry loads of 5 m long lengths of stunning french oak trunk side "fillets" delivered each Spring from my local saw mill.
I then use my trusty Stihl MS180 chainsaw and set to along each length of wood balanced carefully on my saw horse, cutting lovely 9-12" prieces. Burns beautifully hot and slow for 9 months a year 24 hours a day. Stunning value at £450 for all that mountain of wood.
Problem is, it is a LOT of labour, say 8 weekends work. I get through 2 chains (have to do three good sharpening strokes on each tooth and oil refil with each fuel refil).
So I wonder if there might be a better way. Would a bandsaw be more durable, quicker to use?
Any ideas gratefully received!
And do u know how to sharpen a chain correctly as I'm supprised at the amount of sharpening you are doing?? Imagine how much a band saw would need sharpening. A circular saw would be better.tungstan tip.
Yep and there's no way of changing that! Cutting and splitting firewood is hard work and unless you have a £20,000 processor it will always be hard work....
There is an easier way, buy it off one of the log sellers on here. Lol.
Look at the work as excersize. That's what I do. It's good for humans to do a bit of graft, especially if you work mainly indoors as I do. Get stuck in and enjoy it.
Hi,
in short yes but band saw will also need sharpening.
i tend to cut and bag all our flitch wood but use the rack to cross cut it or a chain saw ms390. works ok, get around 15 ton a year in oak, plus other bits.
we've a large band saw 25" throat and takes a 2" band old sagar one that gets used as a resaw and will be quite happy chopping up stuff, usually the 15-20 ft flitch gets thirded and either fed through a cast bench with a 3foot blade tractor driven or the band/ chain saws.
