It looks like the vehicle has had a swing lift or similar “crane” fitted, the wiring is too weedy for a proper winch and there aren’t enough solenoids for a winch but it may well have run a small motor, that and the holes in the bed suitable for a mounting plate says swing lift.
If you don’t want to remove it you don’t need to, the red wire (dangling) is the live and as long as it’s not on the terminal the system is inert, the round things are solenoids (switches for running higher loads) The small wires are the ones that operate the solenoids.
