I shared this on FB and a new user with whom I went to college, and is now a rather off the wall gay abstract artist, and seems to comment on everything, posted the most wonderful observation.... you may even want to use this slogan in the marketing...
Catchy don't you think!
Peter,
My Isuzu rodeo (08 plate) double cab already has a speed liner in the tub, does this matter?
Can the pro tipper be made so that my existing canopy can be fitted to it (present ARB canopy fits into existing fittings inside the tub), or does it need another solution to keeping the logs dry on delivery days?
Cheers
Speed liner isn't a problem, neither are the abs plastic type liners unless they are a really poor fit.
I'm sure we could work out a way of fitting the canopy on a Pro Tipper, does it have g clamps that fit under a lip on the original bed?
The canopy fixes via bolts into threaded holes in the side walls of the tub. This means the tub has no lip but the canopy does.
If you look at the image of the red unit at the bottom it shows it.
http://www.4x4at.com/truck_top_details.php?tpid=25&PHPSESSID=402a62070558f28d85670f05438a31f8
Pretty sure fitting the canopy would be straightforward. If those brackets come off, then you could just sit the canopy on top and bolt it straight onto the wings.
It would sit a couple of inches higher than is does on the standard tub.
