My 038 starts and runs OK But when it is hot it will sometimes cut out
and it will not start when it is hot any ideas
It has new plug and filters Piston & rings are not Marked and Saw is clean
no sawdust on the fin or cases
The next time it happens remove filler cap and replace, if it starts you may have a blocked tank breather creating a vacuum.
that's worth a try,my old jonsereds used to do that regular,unscrew the fuel cap and would virtually pop in your face :scared1:
I the same symptoms and it turned out to be crankshaft seals letting out the bottom end compression, new crankshaft bearings and seals.
Just take off the flywheel cover and check see if theres a bit of play up and down on the flywheel, if not they should be ok
Thanks I will look at that in the morning
The saw cuts fine for about 20 mins been using it today to fell and ring up a 30" Dia conifer then it just stopped almost like fuel or being turned off
I left it for 20 mins while we chipped up and it went again lasted about 15 mins then stopped again
Sounds like your coil is breaking down when hot. Next time it cuts out check the spark with the same plug from it. Leave it 20mins or so check the spark again.
