Mornin All,I've been asked to supply firewood for an all night party bonfire - I'm guessing about 10hrs of burning
I'm thinking of supplying 3-4ft lengths of Birch/Oak/Ash cordwood- but not sure how much they will need,the fire will be around 4ft diameter - I reckon about a cord,but if anyone has any other ideas I would welcome the advice!
I am assuming that there will be someone half sensible keeping it going,but I could be wrong!
Cheers
Steve
If you can, swing by a local sawmill and beg/buy a bundle of slabwood - it'll cost you a lot less but still give the same effect. Round us it's usually worst case £10 a bundle and a bundle is usually thick end of a tonne or so.
I do a party fire in the same place about 6 times in the summer , not all nighter but very close
I load the pickup with 4 4ft by 2ft oak logs , then smaller as i get towards the cab, when tipped up the oak is roughly in the center of the fire ,this lasts all night from about 7 oclock there is 3 cube in the pickup
I supplied a cube of quartered mostly Oak and Birch for a 4hr party that used a log burner in the building, a fire pit outside with a further two brazier type burners. All the fires were lit before the party to get a bed of embers established and folks kept the fires going, with the pit and the log burner eating the most fuel. Just under half a cube left at the end.
Charcoal was supplied by James [ame=http://www.youtube.com/watch?v=A6AfHjUIYv0]Hookway charcoal retort part 2 - YouTube[/ame]
