  • Replies 22
Yes mate, it is my home made saver. I used: Sirius 14mm (produce Teufelberger) double braid clas.1, Tenex 9mm for prusic, sweet Pinto, Edelrid small biner, Petzl rubber protector. And big steel ring from Singing Rocks cambiumsaver. Now i will be made lighter and cheaper model, from 16strand rope without steel ring but with formed eye. Prusic from IceBlue and as pulley i would like try ISC Micro. Or i can made acording to your wish, dont problem. Regards from beatiful hot spring Prague.
Oh yes, perfect working, without problems with retrieve trought big rings. My new model will be better, i hope and so much cheaper. Price original TM pulley saver is crazy for me.
And my climbing setup:
I've spliced Tenex in much the same way but without the sleeves at the pulley eyes. Have you found that they make much of a difference?
Read more
