Hi Marcus , I was hoping i could use it as part of an srt set up , youll have to explain the RADS bit mate :blushing::001_smile:
Rads is very simple, you have your single line with gri gri on, then above it a handled ascender, clipped into the top hole of the ascender a simple karabiner with pulley, the tail of the line goes from under the gri gri through the pulley. Attached to the bottom of the ascender is a foot loop you advance the ascender stand in the foot loop and pulling down on the tail of the line through the pulley will advance the gri gri.
It's a stand sit affair but allows you to both ascend and decend on a single line, particularly useful in pine trees and other situations.
It's also good for occasional srt access if you begin to use it a lot try to vary the leg you use as it can cause problems.
  • Replies 48
Thanks Marc, i had to draw that out on a piece of paper there but it seems a good little set-up , thanks alot :thumbup:
I use mine in the yoyo technique for long hauls Into the crown. Also as my emergency escape route while taking down a stem on spikes, the rope is simply choked onto the stem with a running bowline. The grigri is a great bit of kit and I would hate to be without it.
if you are going down that route, i'd say a rig is a much better bit of kit for it, much easier to install and it has a lock so it wont creep. the rig isnt much bigger unlike an ID.
Jamie
