any old oil
brewpup
  • Replies 32
Quicksilver Premium 2 Stroke Oil
Specifically formulated with a marine additive package to meet the needs of low- to mid-horsepower outboard engines.
For use in normal marine operating conditions.
Exceeds TC-W3 standards.
Reduces rust and corrosion of internal components.
Provides enhanced detergency to help keep your engine free of deposits.
Meets all outboard and personal watercraft manufacturers’ recommendations for use of TC-WII and TC-W3 oils in pre-mix or oil-injected models.
May also be used in snowmobiles, motorcycles, chain saw sand other 2-cycle air or water-cooled applications where an API-TC type oil is recommended.
API TWO-CYCLE SERVICE CLASSIFICATIONS
API-TC - Designed for various high-performance engines, typically between 200 and 500 cc, such as those on motorcycles and snowmobiles, and chain saws with high fuel-oil ratios - but not outboards. Two-cycle engine oils designed for API Classification TC address ring-sticking, pre-ignition and cylinder scuffing problems.
Reliance Marine - Quicksilver Premium 2 Stroke Oil 1 Ltr 92-858021QB1
:confused1::confused1::confused1::confused1::confused1:
Edited by woodchopper
