Wind both screws in until they bottom and then out (anti clock) one turn each and then tune by ear - adjust idle and you are away.
..same for 262XP?
..same for 262XP?
TBH the vast majority of saws are 1 & 1 turns out, the only exception is the 335XPT.
I always start with one turn on each, get a feel for the L setting and once it is right, set the H screw, this can effect the H on some carbs so a balance point is sometimes sought - the old 020AV was one of those.
