Tree pit knowledge anybody?
Dr.Green
been asked to do a job of remove some trees on a development site and then replant new stick elsewhere inc treepits .
apart form removal / replant which is no problem anybody got any information on treepits ??? these are for small trees ..
by the sounds of it a tree pit is just a hole (dont fancy digging with a spade) to plant them in and filled with the relivant soil mix which has been specified, or is the tree pit a contained area to stop root growth outside of an area???
thanks , any help or input whatever it may be is always usfull:thumbup1:
here is the spec
TREE PITS
- Sizes: 1000 x 1000 x 600mm for selected standards.
- 1200 x 1200 x 1000mm for extra heavy standards.
- Sloping ground: Maintain horizontal bases and vertical sides with no less than
minimum depth throughout.
- Pit bottoms: With slightly raised centre. Break up to a depth of 150mm.
- Treatment: Soil ameliorant worked into pit bottoms.
- Pit sides: Scarify.
- Backfilling material: Two parts topsoil and one part tree planting and mulching
compost.
- 150 grams of SLA Enmag or similar and approved slow release fertilizer.
- 100 grams of broadleaf P4.
  • Replies 24
there is a danger in improving the soil in the pit too much, it encourages roots to stay in the pit rather than push out to explore, girdling worst cases.
i did think this also , but if its in the spec and i follow it and cant be held responsible , but on the other hand maybe i should advise of this when i submit my quote:001_smile:
I would want to know the soil type before making amendment specs, if your offering advice, base it on the soil dont just wing it.:thumbup1:
il keep it simple and stick to the spec - from what i believe they have given me a spec on pits and the tree species and i am the boy to do the 'dirty' work as all previous inspections and tests have been made.
one last thing , cant find any information on this
SLA ENMAG
