Monday milling
John Hughes
I will always remember the stick I got from mr delabodge and his crew when I set up in a back garden in Reading. They had watched the Lucas promotional video on which it said the mill could be set up in ten minutes.
Realistically if the pickup can be parked next to the mill then about 20 minutes to put the mill up and then a few more to line up the log with the rails.
John
About right I reckon - I think the Peterson takes around the same time to get set up.... can be fiddly getting it out the trailer as I tend to leave the blade on to save time - this leaves only a cm or so clearance but has worked fine so far....
John
ah but you did a grand job john,lol:thumbup:
