I've managed to put a hole in the oil tank of one of my saws. I took the handle off years ago, but didn't notice that the bolts that hold it underneath are a bit shorter than the ones that hold it at the side, so they got put back the wrong way round. Over time, the ends of the bolts underneath, being a little bit too long, have worn a hole in the bottom of the oil tank.
Has anyone had to make this sort of repair? I was thinking of using araldite or something like that, and gluing something like a c/sink screw head into the hole, or even tapping a thread in the hole and gluing a bit of threaded bar or bolt end in place. Would it stand up to the vibration though?
i personally swear by JBweld for saw repair....
but as with any of these liquid metal/epoxy type magic glues, its important to de-grease the area of the saw you are fixing thoroughly first... to get a good bond. clean it good with de-greaser a couple of times, and because magnesium is so porous it might be an idea to heat the area with a hairdryer first to sweat the oil out of the surface metal...
my 2pence worth....
Great, thanks for replies.
It is metal..some sort of light alloy...probably magnesium, like you say. The saw in question is my 346xp, my favourite saw :bawling:. I'll try the araldite/liquid metal route..might reinforce it somehow as well
my 2pence worth....
JBWeld is the daddy, I have a 5 year old repair on an 020 still OK ( though I gave the saw away to a student recently)
Is that JBweld easily available? I haven't had time to comb all of east lincs, but the local shops didn't have any..I'm using plastic padding "leak fix"..it doesn't sound too encouraging, but that's all I can get hold of in the time available..
