I have received a Stat Notice to remove a considerable number of Larch Trees.
The Neighbouring wood has Phytophthora Ramorum and as a consequence a 100 meter radius round the infection has to be felled or poisoned and a portion of this falls into my wood. This has to be dealt with before the end of April before the Larch start to spore.
I may fell but I would like any information on the best way of killing the standing tree by Ring Barking and the use of Herbiside injection What to use and best practice.?? This would be the quick fix method to comply with the Stat Notice so I may embark on this route before major felling.
Cheers
You can use glyphosate ( Round-up, Gallup) . The product label gives very clear and easy to follow instructions regarding stem injection . You would have to do it now though before sap rise. :001_smile:
exactly
what is enough
Having seen aerial photos of this I can see it popping up pretty random and unexpected
Sounds like the secret is immediate destruction
I guess 100m is probably enough but requires 100% compliance
This disease is a bad one and one that makes you wonder on the sense of monoculture of trees
exactly
what is enough
Seems a good point to me :thumbup1:
Not sure if it will help with your situation directly, but recently we have been using ecoplugs for killing stumps. Glysophate injection that is friendly to wildlife etc. Drill the stump around the cambium, species dependent on the number of holes. Insert cap, hit with hammer.
Quick, neat and the customers seem to like the 'Eco' idea.
